When I press the start nothing happens. I was drying a large blanket earlier and it was not drying very well. I had to rotate the blanket and restart sevveral times. When I removed the blanket and put something new in the start would not work for either the timed or auto function. I unplugged and replugged it and still nothing
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
SOURCE: Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
SOURCE: Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
SOURCE: I have a Whirlpool Model LER4634JQ0 that was used
sounds like the dryer belt is broken or off the pully, does it make any noise at all? if yes then unplug carfully pull out and open to check belt replace if needed
SOURCE: Whirlpool dryer WED5300VW0 runs and heats but
The timer has gone out,replace the timer with a new one.
Testimonial: "Thanks"
