Lexus Car ES, IS, LS 1998-06 Fig. Checking wheel bearings for excessive play
Coil Spring Rear Suspension
Hub & Bearings
Adjustment
Check the backlash in bearing shaft direction and the axle hub deviation. Maximum for backlash should be 0.0020 in. (0.05mm) and for axle hub deviation 0.020 in. (0.05mm).
NOTE
The rear wheel bearings are non-adjustable. If the wheel bearing is out of specifications, replace the wheel bearing.
Removal & Installation
Rear tire and wheel assembly
Rear stabilizer link
Rear axle shaft nut
Rear disc brake caliper and disc
Speed sensor
Parking brake assembly at the wheel hub
No. 1 and 2 upper control arm assembly
No. 1 and 2 rear suspension arm assembly
Toe control link
Rear axle from hub assembly using a plastic hammer
No. 2 rear wheel bearing dust deflector using a screwdriver
4 bolts and rear axle hub and bearing assembly from the axle carrier assembly
To install:
Hub on the carrier and tighten the bolts to 52 ft. lbs. (70 Nm)
Rear axle into hub assembly
No. 1 and 2 upper control arm assembly. Torque the new nut to the No. 2 rear upper control arm to 52 ft. lbs. (70 Nm). Temporarily tighten the No. 1 arm bolt.
No. 1 and 2 rear suspension arm assembly. Temporarily tighten.
Toe control link. Torque new nut to 52 ft. lbs. (70 Nm).
Rear stabilizer link. Torque to 20 ft. lbs. (27 Nm).
Rear speed sensor
Rear axle shaft nut. Torque to 214 ft. Lbs. (290 Nm) and stake the nut with a chisel and hammer.
Rear brake disc and disc brake caliper
NOTE
If it is necessary to replace the hub or bearing, replace the components as an assembly.
If equipped with rear disc brakes, the caliper mounting bolts. Leave the brake line connected and suspend the assembly out of the way.
Brake rotor or drum
4 bolts and pull off the rear axle hub
O-ring
To install:
Hub on the carrier and tighten the bolts to 59 ft. lbs. (80 Nm)
Rotor or drum
Caliper, f equipped with rear disc brakes and tighten the bolts to 34 ft. lbs. (64 Nm)
Wheel
Negative battery cable
Rear wheel(s)
Height control sensor link from the lower control arm
Anti-lock Brake System (ABS) speed sensor and wiring harness
Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire.
Brake rotor
Parking brake shoes and cable
Cotter pin, lock cap and the nut holding the halfshaft to the rear axle
Suspension member brace by removing the 2 bolts
Halfshaft bolts and washers
Halfshaft from the vehicle
Strut rod
Nut and adjusting cam
Nut on the axle carrier side of the No. 1 lower control arm
Separate the control arm from the axle carrier
Stabilizer bar link from the No. 2 lower control arm.
Nut and adjusting cam from the No. 2 lower control arm
Nut and bolt holding the No. 2 lower control arm to the axle carrier
No. 2 control arm from the vehicle
Nut and bolt on the lower side of the strut assembly
2 upper control arm set nuts and bolts
Ahow to install rear struts on a 1999 llexus - 0996b43f802092da.jpg upper control arm
Nut holding the upper control arm to the axle carrier and remove the control arm
Duhow to install rear struts on a 1999 llexus - enlarge_icon.gife a suitable prytool. how to install rear struts on a 1999 llexus - enlarge_tooltip.gif
Fig. Removing the oil seal (inner)-LS 430
Fig. Removing the axle hub from the axle carrier-LS 430 Fig. Removing the inner race (outside) from the axle hub-LS 430
how to install rear struts on a 1999 llexus - 0996b43f802092dd.jpg>
Inner race (outside) from the axle hub
Oil seal (outer) from the axle
Fig. Removing the oil seal (outer)-LS 430
Snapring from inside the axle housing
Bearing from the axle housing
Fig. Installing the oil seal (outer)-LS 430
Backing plate to the axle housing. Do NOT install the bolts or nuts at this time.
Inner race (inside) to the axle housing
Axle hub to the axle housing
Backing plate in position. Tighten the bolts and nuts to 43 ft. lbs. (59 Nm).
New oil seal (inner) to the axle housing. Coat the oil seal lip with multipurpose grease.
Fig. Installing the oil seal (inner)-LS 430
New dust deflector. Be sure to align the hose for the ABS speed sensor in the dust deflector and axle carrier.
Upper control arm to the axle carrier by installing the nut. Tighten the nut to 80 ft. lbs. (108 Nm).
Axle carrier and upper control arm to the vehicle as an assembly
2 upper control arm set bolts and tighten the bolts to 121 ft. lbs. (164 Nm)
Bolt and nut holding the strut to the axle carrier. Tighten to 101 ft. lbs. (137 Nm).
Bolt and nut connecting the No. 2 lower control arm to the axle carrier. Tighten the bolt to 60 ft. lbs. (81 Nm).
Nut and adjusting cam to hold the No. 2 lower control arm to the body. Align the adjusting cam marks and tighten the nut to 57 ft. lbs. (78 Nm).
Stabilizer bar link to the No. 2 lower control arm and tighten the nut to 48 ft. lbs. (65 Nm)
No. 1 lower control arm to the axle carrier and body. Install the nut to hold the No. 1 lower control arm to the axle carrier. Tighten the nut to 43 ft. lbs. (59 Nm).
Nut and adjusting cam to hold the No. 1 lower control arm to the body. Align the matchmarks and tighten the nut to 57 ft. lbs. (78 Nm).
Strut rod to the axle carrier and body. Install the bolt and nut to hold the strut rod to the body. Tighten to 57 ft. lbs. (78 Nm).
Bolt and nut to holdhow to install rear struts on a 1999 llexus - 0996b43f80207fdc.jpge axle carrier. Tighten to 136 ft. lbs. (184 Nm)
Outboard joint side of the halfshaft and align the matchmarks on the side gear shaft and the halfshaft. Coat the threads with clean oil and install the hexagon bolts. Tighten bolts to 61 ft. lbs. (83 Nm).
Fig. Exploded view rear carrier assembly, hub and bearing-
Fig. Exploded view rear Axle carrier and hub assembly-ES 330
Stabilizer Bar
Strut & Coil Spring
SOURCE: replacing rear struts on 1999 Camry
As long as you have the ready struts no. They come with the spring and mount already attached. If you don't, you better have a good spring compressor to remove the old strut and replace it with a new one.
Testimonial: "It's great to get a response this fast. I appreciate it. Thank you."
SOURCE: ihow do you replace rear struts on a 1999 ford
strut assembly removal requires, disconnect the lower spindle clamp should be 1 or 2 bolts and the swaybar links. then remove and replace the 3 bolts on the top of the shock tower (do not remove the center nut)
then remove the srtut.
SOURCE: I am looking for an exploded view of how rear
the struts are very easy to pull off the car, but as to taking the strut apart that is best left to a professional, it requires very expensive special strut cartridge installing fixtures
Testimonial: "Thanks, I have access to the spring compressor if that is what you are refering to. "
