Exercise & Fitness Logo
joe smith Posted on Dec 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
T931 not starting
No display
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Dec 22, 2011
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4078138
Points
34431
1) Exchange batteries by new ones.
2)Tight the flexible cord Keypanel vs display board.
3) Tight the connector from display board vs lower board.
4) Adjust the sensor reed switch see the diagram by 1/8"
5)put your software calibration to work, for diagnostic and adjust.see the instruction in your owner manual y/o under hood.
6) Adjust the speed sensor and tigh the connector very well.
7)Test the main motor for 115VAC, see the plate from motor for to check the voltage.
8)See the main motor board or lower board, Test for 115 Vac, and +5VDC for output from the main controller board and display board
See the block diagram and take the diagnostic very effective. sincerely.
Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Can u start a Honda fourtrax 350 2003 with out display
Yes, you can start a Honda Fourtrax 350 2003 without the display. All you need to do is turn the key to the "on" position and press the start button. The display is not necessary for the quad to start.
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
4helpful
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
8helpful
2answers
Canon_fax_b820_error_342
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If your problem not solved replace the SCNT PCB
1helpful
Mi da errore ##331 .... dopo aver cambiato le cartucce . prima mi dava errore ##342 ... e non mi prende la carta . ho il fax canon b 140 AIUTATEMI Grazie mille
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If problem not solved replace SCNT PCB.
I have an horizon t931 treadmill and when i start the treadmill the clocks start to tick up but the treadmill is not moving, at one point it started and i started running and it the stopped suddenly, can...
Possibly you do not have the magnet on its plate.
There is a small red magnet which is on a cord. The other end of the cord clips onto your clothes. If you fall, the magnet pulls away from the machone and it stops.Hope this helps.
In my syatem, start with no display after windows
start windows in vga mode by pressing F8 at starting after POST. then set the resolution of your screen to 800X600 and restart.
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
2helpful
Clock problem
try holding hte clock/set start button in for 3-5 secs, it sounds as if youve accidently turned of the clock display. .. a common issue especially after turning clocks back.. its a built in feature for people with too many clocks in kitchen, they allow you to turn off the display.
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
john h
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
