Anyone have a wiring diagram for this machine
SOURCE: USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is [email protected]
SOURCE: Bosch exxcel 1400 s express fault
F01 Door not closed properly.
F02 Tap not turne on, Inlet hose kinked or pinched, Filter blocked in water inlet hose, Water pressure to low.
SOURCE: I keep getting error message F04
SOURCE: Bosch Exxcel 1400 Express -
Sorry but I do not know your particular machine even though we have a Bosch. I would suggest, however, as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Testimonial: "Many thanks - you were spot on but I got the info five mins earlier, Thanks again from Ireland."
