The sun symbol is heating, an icicle is cooling, the fan symbol means fan only. A triangle means auto mode, the machine will heat or cool to get the temperature you have selected. Looking at your remote, it is set on 16 degrees cooling. The large fan symbol will mean its on high fan speed.
what about the heater. the a/c and heater share the same fan motor. If there is no force in the heater as well it may the the fan is not turning at full speed. should be able to hear the fan as well as feel the air from the ducts. another possibility is a blocked duct way. If you can hear the fan blowing full speed check the duct for obstructions.
Are you in the United States? If you are, then you are running your fridge on international power settings. United States standard for voltages is 120V, you are running at TWICE that. This is EXTREMELY unsafe and quite harmful to the fridge. Please switch your inverter to 120V.
No they do not have any internal cooling devices. they rely on ventilation alone. I will suggest that you read up on reviews for this item if you are thinking of buying one. They have not gotten great reviews.
Dear friend, find below symbols for mode setting. For cool keep minimum 3 degree less than room temp and heat keep minimum 3 degree higher than room temp. Dry mode will help you only in wintertime. Thanks.
Now symbols: 1. fan leaves - Fan only 2. Rain drop- Dry mode 3. Snow flake-Cool mode 4. Sun- Heat 5. A or AU- Auto mode.Helpful?
Symbolsin remote:
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols: 1. fan leaves - Fan only 2. Rain drop- Dry mode 3. Snow flake-Cool mode 4. Sun- Heat 5. A or AU- Auto mode. First, check your compressor is working?
