Question about KitchenAid Food Processors
My kitchenaid food processor won't work
  • louise stevens Dec 20, 2011
    many thanks both, it's not the power cord as we checked. I think is more likely to be the actuator as it works when we push it in with a cocktail stick but not when the bowl is locked into place so I understand the pin has warn down from over use. Do you kinow where could i get a vinal screw?
    Genius:
  • 1,212 Answers
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Posted on Dec 20, 2011
Testimonial: "really helpful thanks"
  • 2 more comments
  • John McPherson Dec 21, 2011
    You can get the vinyl screw covers at most hardware stores that have the array of small drawers, Jandorf is one of the vendors, there are others, but it is essentially something you would normally put on an exposed screw shank to keep it from scratching people who might rub up against it.
    If you remember those small sheet metal yard barns- they usually packed dozens of them with each yard barn.
  • Gene Odato
    Gene Odato Feb 02, 2013
    i have the same problem. it is not from overuse because i haven't used it that much. but it does work when i push that button in with a stick. i will look for a screw cover. thank you
  • ronald chase
    ronald chase Jun 02, 2018
    Check the small spring inside the handle. Mine was sticking. After applying a drop of oil, the machine finally worked!
  • TJ Kemball
    TJ Kemball Jul 18, 2018
    where did you add the screw? mine is doing this also. those little plastic levers will not go down all the way :(
  • KitchenAid Master
  • 17,130 Answers
The fault can be with the power cord, the switch the motor brushes or the motor winding.
You need to open and check from the power cord , the continuity to the switch and to the motor. There is a safety switch in case the lid is not fixed into correctly as this will not run the motor. Also check for any rest switch in case of a power issue or overload which can trip the motor.
Your question did not mention any observation in detail.
5 Suggested Answers
6ya staff
SOURCE:
QuietRiot
  • 145 Answers
SOURCE: my kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Posted on Aug 08, 2009
Anonymous
  • 89 Answers
SOURCE: Need owners manual for kitchenaid food processor model # KFP740CR
http://www.kitchenaid.com/flash.cmd?/#/page/home
this site should help you out.
one thing, you can chop onions without crying.
Posted on Nov 08, 2009
Remag1234
Robert Allocca
  • 387 Answers
SOURCE: Kitchenaid Food Processor - Center Stem Support doesn't turn
Grease, it needs grease to lube it.
Posted on May 16, 2009
QuietRiot
  • 145 Answers
SOURCE: Need to clean inside of handle on KitchenAid food processor
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
Posted on Jul 07, 2009
Kitchenaid food processor KFP1642MS This model requires the bowl, lid and plunger to be installed before it works. With all items installed this processor has been intermittent and getting worse.
The solution is 90% going to be replace the lid, or replace the bowl or if you are very unlucky replace both. A proper KitchenAid service agent should have both parts on the shelf and will be able to try a new one of either to see where the fault lies. I think over the years I've replaced more lids than I have bowls.
Feb 25, 2018 | KitchenAid Food Processors
KFP0711 Kitchenaid food processor won’t turn on even when put together. Just opened and never been used.
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
Nov 24, 2017 | KitchenAid Food Processors
Kitchenaid kfc 3100
Probably the mechanisms in either the bowl or the parts of the lid that engage the bowl mechanisms.
Aug 31, 2012 | KitchenAid Chefs Chopper KFC3100 3 Cups...
KitchenAid Food Processor bowl is in wrong position and locked
Thank goodness you have solved it, help was a long time coming. It's a shame these threads don't self lock after a certain period.
Apr 01, 2012 | KitchenAid KFP715 7 Cups Food Processor
Food Processors Logo
18,395 people viewed this question
Top KitchenAid Food Processors Experts
ismash55
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
