Haven't been able to find the right code to program the Direct TV remote to my Element LCD TV. They list 0178 but that doesn't work. I have called Element they said the TV is made by Proview Technology. Anybody have any suggestions on how to have one remote that does everything. It is annoying to turn the TV on and the volume with the Element remote and then have to use the Direct TV remote for everything else.
We cant find our original element remote control. I just tried 10178 on the direct tv remote control and it worked YEAH!!!! We just can't do the screen size edit thing with it :(. Might still have to order a replacement element remote. This works for now. Thanks.
Code 10178 did the trick with a new Direct TV Remote Element TV. Thanks Terryhoney!
How do you put in the code ?
Try these codes i got from my local cable company
1144, 1240, 1331
10178 worked for my 32" elchw321 but unfortunately you cannot switch between inputs with this code..everything else works though, i have hooked this up with direct tv RC64 remote
I have a Direct TV Remote that says RC23 in the upper left hand corner, can't find a direct link to it on Direct TV's website, but the following link I found online appears to be my remote.....
http://www.directv.com/learn/pdf/Remote_Controls/universal_remote_user_guide_new.pdf
I found another post online that suggested I use the GoldStar Code, which I looked up and typed 10030. This turns the TV on and Off as well as Volume, don't know what else it will do, but those where basically all I was after. The Goldstart code might work with other Direct TV Universal remotes as well, but I can't test as I don't own one. Good Luck!
Ishousewife solved my problem with the post above. I searched for Proview and got three codes: 10835, 11401, and 11498. The first number worked like a charm on my Element and I am now a happy camper.
I tried 10030 for the LCD Element 40" for Direct TV Remote it works!!!!!!
There is help. Just go to : www.urcsupport.com
HAVE YOUR REMOTE NEXT TO THE COMPUTER so you can chose the right one. You will get your code.
Have your Olevia model number handy also. It is in the set up papers if you kept them, or must be on the back of the TV.
Good luck.
I just bought a 40 inch Element LCD and the code for Vizio worked, 0885. Hopefully this helps:)
Yes i tried it an it works it proview that makes the element tvs now my remote is workin find
Nothing seems to work on my Element TV I have a z remote the old one
Element 40" LED HDTV (ELEFW408) code for use with Suddenlink (Atlas OCAP DVR) 1056B03 Remote Control is 2183.
I finally got the code by calling Element and asking who made their TV. They said ProView. When the Direct TV guy came out I asked him to search for the code under ProView and he found it. My remote works fine now. If anyone else has this problem with an Element TV, try searching for your code under ProView.
I have an element lcd 32 inch tv. Need the codes for this. also have a direct TV model D12-300 box, which I need the code for. Trying to program a yamaha RAV311 universal remote
I have time warner cable remote which does not have the codes for element 32" tv . Does any one know what codes would be compatiable to element tv and time warner cable remote?
I can't program my direct tv remote to my Element HD tv. There isn't a choice for Proview. Anyother suggestions?
i can not find the code for my element 40"lcd tv.i need the code so that at&t u-verse can set my remote on my wireless box.thank you.
Can't get remote to work.
i want to control headphone volume from remote control
I need help to program my universal remote to my element tv
