make sure ur desktop manager and software is installed then Remove the battery from the BlackBerry smartphone .....Open the BlackBerry Desktop Manager.....Connect the BlackBerry smartphone to the computer without battery ie only on charger...Click Application Loader....Under the Update Software heading, click Start....Click Options. This allows you to add or remove applications from your phone Select the applications that you want to install. Next. Next. Finish. Once the application load process starts, insert the battery. then u r ready to go
I downloaded 2go mobile chat using my Blackberry 8520 I did login once but when I login again it says check your GPRS please help with that problem please
Hi there!
Try pulling the battery out while your BB 8520 is switched on. Hold the power button for 30 seconds before connecting the battery back. turn on your phone and reconnect it if it asks you to reconnect. If this doesn't work, I suggest bringing it to a qualified technician.
Hope this helps.
you have likely dropped your phone and this has caused the lens to move.....open the back of your phone; remove the battery and gently press on the camera lens. Replace the battery and start your phone up again....see if this helps.
the blackberry curve 8520 doesnt have any pre installed software or application that will block a certain number from calling/texting us.
Sprint cannot stop this because that number/user initiates the text message and they cannot get that one particular sender to be block on their server so you will not get any messages from that number.
2 Possible solution
1. you can buy the black/list software for curve 8520 that will allow you to block that number to call/text you.
My Blackberry 8520 just shut itself down and when I try to turn it back on nothing happens but when I put it into the wall charger the red LED light comes on and a charging symbol but still doesnt switch on.
Ive tried of mulitiple occasions taking out the battery and rebooting it but still no sign of any life? Any Idea's?
