Question about Samsung RS2630SH Side by Side Refrigerator
Samsung RS21DCSV side by side fridge/freezer. prob with icemaker
Stopped making ice recently. The ice tray was sitting at a funny diagonal angle. Tried the reset button but the tray is now sitting upside down and has had water pouring onto it. I had to raise the lever to fool it into thinking the ice compartment is full so my freezer would stop getting water trickling in from the icecompartment. Can anyone help with this
  • nicko101 Oct 16, 2008
    g'day i have a samsung srs614dw fridge/freezer that has ice and water in the door.i turned off the ice maker on the front door about six-eight weeks ago.but know that i turned it back on i will not work or make ice.can you help thanks nick
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: ice tray stuck
Hi My Samsung freezer was nor a RB2155 it is a RS2630SH however after not making any ice because the tray was stuck in the upside down position or thereabout after 6 weeks it suddenly started making ice again, we had not done anything to it but we heard it dropping ice one evening and we had a look in the ice container and low and behold the ice box was full to the top, I would still like to know why it went like that in the first place in case it happens again it is a mystery. Larry
Posted on Dec 23, 2006
stephanos18
Steven White
  • 144 Answers
SOURCE: icemaker tuns but ice does not drop out
OK the reason the Ice isn't dropping is that the element under the icecube tray isn't working. You'll need a new Ice tray with element I'd be guessing, but see how you can buy it. Some models you need a whole new ice maker. Cheers
Posted on May 21, 2009
BIKER T
Terence Fourie
  • 909 Answers
SOURCE: Samsung side-by-side fridge freezer model
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Posted on Sep 17, 2009
Testimonial: "Thank you. Have followed your advice and temp has been stable continually since. Many thanks, you've saved me a few bob!"
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Please help. I have a Samsung RS2555SL
I will assist you with your ice maker problems if you like, Thanks Sea Breeze
Posted on Nov 26, 2009
Freezer not making ice
Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Aug 25, 2016 | Samsung RSH1DTMH American Style Silver 524...
Ice maker not dumping ice.
sounds like the icemaker timing or motor is bad. those parts are not replaceable on this model, you would need a new icemaker assembly
May 02, 2012 | Samsung Refrigerators
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Samsung RS267 Icemaker too slow - not waterline
Hthere........sounds like your settings are all askew.....however help is at hand....simply log on to ww.samsung.co.uk (if your from the uk) go to product support.....enter your model number....and hey presto they present you with an online manual which you can print
regards Sir Galahad
Aug 16, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Icemaker tuns but ice does not drop out
May 21, 2009 | Samsung RM255LASH Side by Side...
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
177 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
