Hi there On your remote there should be a "adjustment" button, push that and on the screen appears a picture of the different ways you can adjust your screen and choose accordingly.. good luckkolbrun
TO PROGRAM THE remote USING THE 3 DIGIT CODE: 1. Turn on the TV receiver 2. Press TV on the Sky Remote Control 3.
Hold down SELECT and the RED buttons together for approximately two
seconds, until the RED LED on the Sky remote blinks twice. 4. Enter three digit code from list for the receiver (early versions now flash twice). 5. Press select to enter code structure (the LED will flash twice if a valid code has been entered). 6. Now press the STDBY button and test other functions. Repeat if necessary until a code is found that works most common functions. TO PROGRAM THE remote USING THE 4 DIGIT CODE: 1. Turn your TV on. 2. Press tv on your Sky remote control. 3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice. 4. Press tv on your Sky remote control again. 5.
Key in the four digit code for your brand of TV. The light on the Sky
remote control blinks twice. If the light blinks once only, recheck the
code for your brand of TV and start again at Step 1. 6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code). If
at this point the LED on the Sky remote control blinks three times then
all possible codes for that make of receiver have been checked. Repeat
from step one, ensuring that you enter the correct manufacturer code. At
the end of the sequence, if you see the TV Guide screen, the remote
control setup process is complete. If you did not see the TV Guide
screen, you must now complete the following steps. 8. Press tv on your Sky remote control. 9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. 10. Key in the number of the channel on your TV that you use for watching satellite TV. 11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete. If
after trying this, you still have problems, call your broadcaster's
help desk. For your broadcaster's help desk number, select the
Telephone Numbers option from the Services screen.
seconds, until the red light on the Skyremote control blinks twice.
4. Press tv on your Skyremote control again.
5. Key in the four digit code for your brand of TV. The light on the Skyremote
control blinks twice. If the light blinks once only, recheck the code for your
6. Press the standby button on your Skyremote control. If your TV
switches off, press select. The light on the Skyremote control blinks
If at this point the LED on the Skyremote control blinks three times then all
possible codes for that make of receiver have been checked. Repeat from step
At the end of the sequence, if you see the TV Guide screen, the remote control
setup process is complete. If you did not see the TV Guide screen, you must now
8. Press tv on your Skyremote control.
satellite TV.
11. Press select on your Skyremote control. The red light blinks twice. The
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide . If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice. If the light blinks once only, re check the code for your TV and start again at step 1.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide . If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
