SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
you can get the wheel here
http://www.amazon.com/Graco-Quattro-Deluxe-Stroller-Renaissance/dp/B000CEXO0C
SOURCE: Replacement footrest
What brand is it? Look up that company online or contact them by phone. Most companies should have replacement parts available if the stroller isn't too old. Good luck!
SOURCE: bell stroller left back wheel
I have same problem... I took the main bolt out that holds the plastic pieces to the metal frame, that holds the wheel assembly on that side. I pulled it off and found that the aluminum frame had actually ripped, broke a metal section off under the plastic area... Looks like the frame would have to be re-welded to function again... Take that area of your wheel apart, and see what is hiding beneath the plastic covering... Good Luck...
SOURCE: back wheel on my stroller is buckled
Hmm. You may be out of luck. Sometimes on the lower end brands, the back wheels may be riveted on to the frame, but if they are removable, you should be able to get new wheels from the manufacturer directly. www.gracobaby.com 1-800-345-4109 .
Good Luck! from Moms Just Know
SOURCE: baby trend expedition double jogging stroller
No but if you just sort of push on one side of the handle bar it will pull it to turn without lifting the front.
