The beater will not come off my Kitchenaid stand mixer. How can I get it un-stuck? Thanks!
SOURCE: KitchenAid Mixer Squeaking
I would first get some canned air. Spray out the area around the Shaft. This is to make sure no harden food is up there. After that is clean spray some cooking spray "PAM"in the Shaft area. This should help. Good Luck
SOURCE: Beater does not turn
It sounds like the nylon gear is stripped out. It is a rather easy to replace and also inexpensive. A gentlemen posted a step by step site to replace the gear. The link is http://www.neilcrockett.com/mixer.htm
Good Luck
SOURCE: kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Testimonial: "Thank you for your post. I will check out the suggestionsl"
SOURCE: KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the
wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways
round, there is a key on one corner which means it will only go in one
direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had the same problem and the spraying it with Veg Oil and waiting for 10 mins worked for me. Took some wiggling back and forth but came free. Thanks!!!!
