Hello! My pixma ip 4600 don,t printing any black and magenta colours.I am alredy clean print head but with no any results.
In most cases the
printer driver software can have errors while being in use or is shut down. So
to reset remove your printer from the PC and uninstall the printer software.
Now reinstall the printer software and then connect the Printer ONLY WHEN
PROMPTED, to be detected as a new hardware as it will be installed. Now check
the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that
the head is not reacting to the need of the PC command or can be an issue with
ink drying or poor ink cartridge contacts. . Also check the mechanical settings of the ink
cartridge , if jammed or tight remove motor and manually free the drive before
it is set back.
Cleaning ink cartridges takes up a lot of ink. So, you may be out of ink in the respective ink jet cartridges that supply ink for the colors which are missing. Try new ink cartridges.
