1979 briggs and stratton 11 hp how to fix
If it is, as you say, a 1979 or so engine, the crankcase breather could have well worn out. This will cause the oil burning and blowby. Replace the breather as an assembly, they are cheap and available from any Briggs dealer. The leaks are probably loose bolts and/or bad gaskets. You will just have to figure where the leaks are and replace the appropriate gasket. The breather could also cause the leaks so do the breather first then run it for a while to see if it is still leaking
