A little well at the bottom of the freezer keeps filling with water which then becomes ice. Water then spreads acroos the ice and out of the freezer door and onto the kitchen floor
Dear Damian sounds like the drain from the freezer is clogged you need to unclogg it and make sure the water flows through. Now if its not visible you need to unplug the fridge take out the shelves and unscrew the back panel.Then at the bottom of the evaporator (the winding pipes ) there should be a block of ice which needs to be defrosted until you see the drain hole that must also be free of ice and that will be the hardest part. To unclogg the ice from the hole you will need some hot water to pour into the hole let it melt a bit then sponge it out and repeat process until the water flows directly through. hope this helps good luck. regards Tony
