Cars & Trucks Logo
A
Anonymous Posted on Dec 07, 2011
I have a 97' daewoo dsl601 skid steer that the boom and bucket won't move
  • Michael Hood
    Michael Hood Sep 20, 2016
    Can you tell me if you ever got a answer to this question? I have one that is doing the same thing and cannot find answer to problem . thanks for your time
Marvin
Level 3:
Top Expert:
  • Daewoo Master 85,242 Answers
  • Posted on Sep 20, 2016
Marvin
Daewoo Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29036688
Points
266281
You most likely have a defective hydraulic control valve, I would start the testing there.
2 Related Answers
gerry bissi
  • 4390 Answers
  • Posted on Oct 05, 2011
SOURCE: 97 mountaineer oil pan won't come out do you
V6 or V8?
V6:
Section 303-01B: Basic Engine - 4.0L SOHC 1997 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Oil Pan
Removal
  1. Disconnect the battery ground cable.
  1. Raise and support the vehicle; refer to Section 100-02 .
  1. Remove the oil pan plug and drain the engine oil.
  1. Remove the ten oil pan bolts and remove the oil pan (6675).
    • Discard the gasket.
Installation
  1. NOTE: All sealing surfaces must be cleaned prior to assembly. Use metal surface cleaner F4AZ-19A536-RA or equivalent meeting Ford specification WSE-M5B392-A to clean the sealing surfaces.
    Position the oil pan and gasket and install the ten retaining bolts.
  1. Install the oil pan plug and refill the engine oil.
    • Use 5W30 engine oil meeting Ford specification WSS-M2C153-G.
  1. Lower vehicle.
  1. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
    Connect the battery ground cable.
Nick
  • 129 Answers
  • Posted on Dec 13, 2011
SOURCE: how to replace key lock cylinder 97 pontiac gran
have you tried turning the wheel while turning the key?
sometimes it gets locked out
John Deere 320 Skidsteer hydraulic lock up for boom and bucket. Code F9H9.
We don't really deal with heavy machinery here. Either ask over at www.justanswer.com or get yourself a service manual for it. Unfortunately John Deere charge for them, but they are very detailed.
https://www.google.com/search?q=john+deere+320+skid+steer+service+manual+pdf
Whats going on with my skidsteer?
Is your hydraulic fluid full?
WIRING FOR CID brush swing boom
    Wiring Harness for swing boom - Skid Steer Genius
    www.skidsteergenius.com/blogs/news/.../wiring-harness-for-swing-boom
    Aug 21, 2015 - Posted by Robert Leib in bobcat 7 pin cable for swing boom, CID ... The CID Swing Boom, Prowler Swing Arm & Spartan Articulating Brush ...
    WIRING FOR CID brush swing boom - Fixya
    www.fixya.com/cars/t26003553-wiring_cid_brush_swing_boom
    4 hours ago - WIRING FOR CID brush swing boom - Cars & Trucks question. images for WIRING FOR CID brush swing boom
How do I replace lower boom pins on L175 skid loader
the pins will be parallel for the length that is in the bushes and arms . The rest will be tapered to enable fitting of the pins if the holes are not exactly aligned
The question I asked is for 1996 773 bob cat skid steer.why bucket won,t go up or tilt
Check hydraulic pressure. Just because you changed the pump two years ago doesn't mean it isn't bad again.
1helpful
I have a caterpiller skid steer loader , dont know what year, but it will run fine for about 20 minutes then just stall . The only thing that moves is the bucket , the rest just shuts off.do not know what...
It has to be a fuel line or filter plugging up after 20 minutes. Look for and replace the fuel filter. The bucked just works on residual hydraulic pressure and has nothing to do with the problem.
My steering wheel locked and my key won't turn so I can start the ignition
Common problem with steering locks is that they can jam in position I recommend putting the key in and gently moving the steering wheel side to side as far as it will reasonably go without struggle and maintain even pressure on the key, this should hopefully work after a few seconds.
Hope this helps, Sion.
Top Daewoo Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Daewoo Expert? Answer questions, earn points and help others
