The oven door will not close completely. More spefically on the right side (when facing it) the upper right corner seems to not be flush against the oven causing the heat to escape through that area. Any suggestions?
Hi someone lifted up on the door this ishowyou remove oven doors open the door about 1/3 then push down towards the floor it should go back into place, if not you may have to remove it clean the hinges then re-install it , I don't think anyone could have bent the hinges cause that would b very hard to do, but i have seen it done before , get back to me Frank
The problem ended up being that our hinge spring was weaker on one side and the smaller locking mechanism was bent. We replaced both of the hinges on an easy fix (youtube video) and saved a lot of money along the way. Hope this helps.
I have never replaced a door spring working at grocery stores for 25 years never once !
