TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
TIME AND DATE
CHRONOGRAPH
4. Press ADJUST to view lap time. Press again to resume lap timing.
Press and hold "MODE". Press MODE 2 times (after the first time, the
alarm time flashes, after the 2nd time, the second flashes). Press ADJ
to change seconds. Press ST/STP to switch from seconds to minute. Press
ADJ to change minutes. Then press ADJ to change hours. Press MODE when
done.
To change time and date setting in your G Shock model
2688 330A, please follow the steps I'll provide below:
1. Hold down "A" until the city code flashes while the watch is in timekeeping mode. 2.Press "C" to scroll through the time setting options. You will see "Hour" and "Minutes," among other options. 3.Press "D" when the option you want to change is flashing. 4.Press "D +" to change the hour and minutes.
Welcome to FixYa!
Here's your request.
TIME AND DATE
CHRONOGRAPH
Thank you for using FixYa!
Have a great day.
Jas247
Time and date setting are only necessary if automatic setting by radio broadcast is unsuccessful. To set time, date, and options: 1) With time and day showing, press and hold SET. 2) City code flashes. Press START/STOP to select city that represents your time zone. See table below for city codes. 3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF). 4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to scan values 5) Press MODE. Minutes flash. Press START/STOP to change minutes 6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero. 7) Press MODE. Year flashes. Press START/STOP to change year. 8) Press MODE. Month flashes. Press START/STOP to change month. 9) Press MODE. Day flashes. Press START/STOP to change day. 10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format. 11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is selected, watch chimes on every hour. 12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is selected, watch beeps for every button press. 13) Press SET, at any step, when done setting. Press and hold MODE to switch between 12- and 24-hour time format. Press SET to view date. Year is at top of display and date is below. Press RECEIVE to view current city. Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK SYNCHRONIZATION section.
Normal screwed down. First pull out position. Second pull out position.
Setting the Time: Pull out the crown to position 3. Rotate the crown to set the exact time. Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not. If the date changed, then you will need to advance at least 2 hours before moving on to set the date. If you do not need to change the date, return the crown to position 1.
Setting the Date: DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am Pull crown to position 2. Rotate the crown clockwise to set to the correct date. Return the crown to position 1.
Setting the Alarm [12 hour] Pull the crown to position 2. Rotate the crown anti clockwise to move the alarm hand to the desired time. Return the crown to position 1. To activate the alarm, press the 8 o'clock button. You will hear 2 beeps. To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep. NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life] The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown You can specify a countdown of between 1 and 10 minutes. Press the 4 o'clock button to enter setting mode. You will hear 1 beep. Press the 4 o'clock button to move the central timing hand successively to the desired countdown time. Wait 3 seconds for the watch to automatically exit the setting mode. You can change the duration of the countdown [except in the last minute] at any time. e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown: Press the 2 o'clock button to start the countdown. You will hear 2 beeps. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing. When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone: There are 2 beeps every minute. in the last minute: 50 seconds=1 beep. 40 seconds=1 beep. 30 seconds=2 beeps. 20 seconds=2 beeps. 10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer: After countdown has finished the timer starts automatically. The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96. Press the 4 o'clock button to see the timer seconds [display lasts up to a minute]. Press the 4 o'clock button to see the timer hours. The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer: Press the 2 o'clock button to stop the timer. You will hear 1 beep. Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer: Countdown reset: Press the 2 o'clock button to stop the countdown. You will hear 1 beep. Press the 4 o'clock button to reset.
Setting the Timer: Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes. Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial. Press the 4 o'clock button to reset.
Resetting the Hands: If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation. To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second. Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12]. Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60. To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position. Return the crown to position 1.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
