Motor runs but will not turn
SOURCE: Newish mixer just stopped while mixing...no motor smell or strange sounds...
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
SOURCE: Kitchen aide mixer
i noticed my kitchen aide mixer is sounding like it is bogging down slightly while it is running it is not used very much and bought christmas 2007 others who own them have said theirs doesnt do that should i be concerned
SOURCE: kitchen aid heavy duty 325 watts mixer won't turn on
On my K5SS mixer, the brushes are aligned with the sliced off corner at 11 o'clock on the left and at 5 o'clock on the right. So the real key is in the suggestion from Mazlynn detailing the use of a flashlight to determine where the little tabs are located inside the brush holders.
SOURCE: kitchen aid--heavy duty mixer
The beater is held in place by a pin and spring arrangement. Lift and twist the beater. If that doesn't work, the pin is trying to come out...and is wedging against the beater. Tap the pin back in a bit, and the beater should release.
Regards, --W/D--
SOURCE: my kitchen aid mixer motor is running but the
jpa4 - If the motor's running but the mixer blade (agitator) won't turn, then you've had a mechanical failure in the transmission box or planetary gear assembly of your mixer. The inspection and troubleshooting of the transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, and then select Parts List file. You can check the page titled 'Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. It can be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc. Good hunting... I hope this helps - Howard, Burke, VA
