I have a hose connected to drain on a constant basis. The red light indicating the bucket of full is on and this stops the unit from working. I emptied the bucket and replugged the unit in and reconnected the draining hose. After turning the unit on for 5 seconds the red 'bucket full light' goes on and the unit stops.
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
SOURCE: Problem with draining water through hose
I raised mine up on a platform about 6 inches, and now mine works fine. Don't know why this is necessary, but atleast it works now.
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
SOURCE: Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
SOURCE: Hose line is no longer draining the unit, bucket fills instead
Sounds like the connector hoae came off inside the machine . Look up inside the machine where the bucket would go and you should see where the hose attaches to the condensate drain . It might have pulled off .
