SOURCE: LHD45EL Dehumidifier won't run
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 1 year old.
SOURCE: "CH 01" shows on the display screen
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
SOURCE: LG LHD45EL
The temperature sensor on teh suction return line from the coil has drifted out of spec and needs to be replaced. This sensor is part of the sensor assembly which plugs into the control board. I purchased the part from Appliance Factory Parts on line, cost about $30, an hour or 2 to change depending on your mechanical level, it is easy to do. For Goldstar DH404E part # was 6877A30013M, they are same part for many models but if this is not the right # for your model just get the right "sensor assembly" for your model and change it out. It consists of Temp/humidy sensor in coil, temp sensor in suction return line, and plug harness that goes to float switch. My uni is running like new again.
SOURCE: LHD65EBL Code CH 01
I had the same problem, and I wound up calling LG's customer support line. The rep I spoke with says that the "CH" code means that the internal thermostat is not able to accurately read the air temperature, and the unit will require servicing.
She gave me a couple of numbers for local folks, and I'll call them in the next day or so, but I'm thinking that this may not be worth the repair, unless it's pretty cheap: I bought the unit for under $100 less than 9 months ago, and I'm not eager to shell out a bunch of money to get it repaired.
SOURCE: My LG LHD45EL Dehumidifier is showing a ch 01
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
