Need cheap service manual for RadioShack sta-18 Stereo Rcvr service manual
SOURCE: Have Realistic Musical Powerhorn - 94 Songs - New
angelgirl 1
please call me 951-545-1827. i have the manual. i can send you a copy.
sheryl
[email protected]
SOURCE: Realistic (Radio Shack) model STA-430 AM/FM Stereo
If the receiver is a new one (a couple of years) I suggest you don't replace the balance potentiometer. It's a potentiometer with rare use so the inner carbon film can't be destroyed. I suggest you to open the case and use a contact cleaner spray (clear, without oil) and spray direct at the potentiometer. Turn it all the way from left to right many times. When it will come dry you will see the diference. As far as the suggestion for clear (without oil) contact cleaner spray, I insist on that because the lubricating oil will cause a trap for the dust and will ask for cleaning again and again. Also for potentiometers with rare use there is no need for lubricating oil.
I think that this solution is much easier than chanching a potentiometer, since the device is not too old.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
SOURCE: trying to find realistic sta
Try going to Realistic.com They usually have schematics and manuals.
SOURCE: service manual for realistic STA-2080
I have a sta-2080 realistic receiver and wide range frequency equalizer plus a tape deck sct-22 all realistic.My problem is when i play the tuner or cd player witch is connected to the aux
the volume goes soft and then loud with a lot of cracking sound now ther is hardly any volume.when i play the tape deck it has it own volume control every thing is good so what parts do i need. thanks corneil
