JVC HD-52G786 52" Rear Projection HDTV Logo
Posted on Sep 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gray spots on screen on a JVC HDILA model HD 56G 787
I have a JVC HDILA model HD 56G 787. I love this TV more than any I have ever seen. However, I have recently (in the last couple of months) noticed slight gray spots near the middle and near top of the screen. The spots are not TOO dark, but can be seen on a white or light colored screen. It almost looks like there is dirt or dust on the screen, but the screen is spotless. Have you heard of this, and what do you think can be done about it? Also, the lamp has been replaced about 2-3 month ago, but it think that it was doing this even before the lamp was replaced. I appreciate any insight. Thank you.
  • 1 more comment
  • Anonymous Oct 09, 2008
    same spots on screen jvc hd61fn97
  • ultracave Oct 13, 2008
    Same grey spots here they are just pepperd all over the screen ....light gray show up the best when the scren is all in white!? need help those little spots are a real pain !
  • Anonymous Oct 31, 2008
    we sent in to get worked on they fixed it. wife neglected to ask what was problem. Have a spot in the middle again now. Lamp has just gone out so I am having serviced again. I will be asking this time what the issues was
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
5771
Points
20
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Anonymous
Level 2:
  • Expert 320 Answers
  • Posted on Oct 31, 2008
Anonymous
Expert
Level 2:
Answers
320
Questions
5
Helped
138758
Points
865
Spots on the screen/picture can be caused by three things. Dust on the inside of the screen, on the mirror or in the light engine or optical block. The first two can be corrected by you if you can gain access to the interior. If it is the third (light engine. it will require a technician. If this answered your question, please be sure to rate the answer. Thanks!
1 Related Answer
wjurls
  • 14 Answers
  • Posted on Dec 29, 2008
SOURCE: Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Mirror has come loose in light engine tunnel how do I fix, jvc hd 56g 786
The entire unit comes out to the rear. Then you have access. BTW, you can operate the TV outside and project to a wall. You may loose viewing permission of copy protected signal via HDMI.
Jvc hd56fn97 56-inch 1080p hdila rear projection tv with convergence problem, how do i fix this
That set cannot have a convergence problem as it has no convergence circuit, It is a DLP set with a lamp.
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
1helpful
2answers
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
2helpful
Spot on JVC hd-ila screen
There are several things that could be causing this. Dust or foreign matter on the inside of the screen, dust or foreign matter on the reflecting mirror or dust in the optical block or light engine. The first two can be fixed by you if you can gain access to the interior. The third will require a technician. If you have had your question answered, please be sure to rate the solution. Thanks!
8helpful
16helpful
4answers
JVC HD-56G886 56INCH REAR PROJECTION TV
I fixed it!!!! If you can open one of the sides (on the JVC there is a little door with a screw), then you can clean the projector lense in the middle on the bottom. It kind of looks like a big light bulb. It seems there is just dust on the glass that is projected onto the screen. We had a big gray spot and cleaned it with a damp glass cloth and Ouila! It disappeared. I scored MAJOR brownie points with my husband for this one! He wanted to replace the TV!
JVC HD TV MODEL HD55G
kinda like a water mark... i fixed a few of these and to me it sounds like something in the optics. eather on the mirror or in the engine... send it to a shop while its still under warrenty. they probally will replace the engine for you under warrenty.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
