I used the self-cleaning on the top oven and hand wiped it down the next day. I then tried to start the self-cleaning on the bottom oven, but then gave me the error sign of E3 FI E3 and my bottom oven will not open. I talked to a service rep and they told me to shut off the breaker for the oven and turn it back on. The error sign was removed, but the lower oven still won't open. I tried to lock it and unlock it, but it still won't open.
SOURCE: Whirlpool Double over
Whirlpool RBD245PDB6 went dead and locked up during self cleaning. It was the third or fourth time in 8 years we used self cleaning. The TCO in the back was open, replaced it but still inoperative. I found a thermal limit fuse in line on the black wire leading to the printed circuit board. It too was open, after replacing it the oven works fine. Check both fuses.
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
SOURCE: After usung the self cleaning function the oven no longer works
The quickest easiest solution is to call an appliance repair place and have them come and fix it. I have had the internal fuses blow on on three separate occassions, all caused when the self cleaning function was used. Another solution is to place an inline circuit breaker to the fuse so the breaker will pop first rather than blowing a 40 dollar fuse. The circuit breaker should not be greater voltage or current rating than the fuse if you choose to go this route. Otherwise, its pay the repairman to replace it.
Tom B
SOURCE: We tried using the self clean on our Whirlpool
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
