Blades spinning at high rpm's ??? but copter only maintains or looses altitude,no lift power.
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
Tell if the copter is lifting w/o turning.............
