Sewing Machines Logo
A
Anonymous Posted on Feb 07, 2018
Bernina 630 pressure foot won't stay up. What do I do?
I have been quilting with a walking foot on my Bernina Artista 630. It was going great and the quilting was beautiful but the pressure foot started going down on its own and won't come back up. I had to lift it up manually but when I start sewing, it goes back down again. What do I do?
Rene Williams
Level 2:
Habit-Forming:
  • Expert 93 Answers
  • Posted on Feb 08, 2018
Rene Williams
Expert
Level 2:
Habit-Forming:
Answers
93
Questions
Helped
27620
Points
267
Make certain that the foot is firmly attached to the bar. If that is the problem (it won't stay in place on the bar) you may need a new or different foot.
5 Related Answers
Anonymous
  • Posted on Sep 23, 2008
SOURCE: stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
Anonymous
  • 19 Answers
  • Posted on Jan 07, 2009
SOURCE: Bernina Artista 630 Turns Itself Off
My troubleshooting would involve taking it in to a Bernina certified technician as it would involve pulling off the covers of your machine for a look. Often this can be the cause of overheating due to high levels of lint build up from people using compressed air to blow out their machine (compressed air is notorius for blowing lint into other areas of the machine) I have also seen the odd plug end swell because customers use harsh cleaning products and it will then not seat properly.
Anonymous
  • 69 Answers
  • Posted on Feb 09, 2009
SOURCE: Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Anonymous
  • 323 Answers
  • Posted on Mar 20, 2009
SOURCE: Looking for a walking foot
Take the machine to an independent dealer and let him show you it works before you buy it.
sewman7
bargainbox
Hassy
  • 1388 Answers
  • Posted on Sep 02, 2009
SOURCE: #50 walking foot instructions
The arm on the walking foot needs to be above the needle clamp to be lifted as the needle moves.
Hi, I have a Bernina Artista 630 I turned it on but the machine screen started Flickering. can anyone help? what is wrong I've been doing quilting and did some embroidery
https://www.manualslib.com/manual/787495/Fritz-Gegauf-Bernina-Artista-630.html
Check power status LEDS behind service panel. See service manual on how to access and interpret
My Aurora 440 is not feeding my quilted fabric through when stitching?
You probably need to adjust the presser foot pressure (see your owner's manual) and install a walking foot.
Walking foot 50 with three soles and seam guide BERNINA
1helpful
How to install Bernette 65 walking foot?
Here is the link to the manual for the Bernette and it shows how to install and use the walking foot. Good luck with this! THe Bernina is a great machine.
http://www.manualslib.com/manual/389081/Bernina-Bernette-25.html?page=61
2answers
Bernina Binding Foot
check on youtube for a video
Bernina 180 pressure foot settings
it sounds like the feeddogs are not holding the fabric against the
presser foot,, check the feeddog to see if they are up, where you
can feel them with your finger in the needle plate area
I need to know how to change the pressure between the foot and the sewing plate. I have no problem doing regular sewing but when I try to do several layers (such as quilting) the pressure is too much and...
The rotary control on the left-hand end of the sewing arm controls the foot pressure. You shouldn't normally need to vary this, except when quilting thick materials. The control is normally set with the 'bar' in the middle of the knob straight up-and-down, but you can reduce the pressure by turning it - the markings on the head cover correspond to increasing and decreasing the foot pressure.
I hav e Bernina 1150. When I attach the walking
Hi, when you quilt straight lines using the walking foot, you need the feed dogs up, to move the fabric in a straight direction under the needle. When you do free motion quilting, which is done with a darning foot, your hands move the fabric in many different directions. Since you want to be the one to move the fabric, you put the feed dogs down and you do the work. So when you use the walking foot, keep your feed dogs up. When you use the darning foot, feed dogs down.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
