I am having problems with my Adobe After Effects 6.5. I am making a 10-second animation for a logo for my production class. Sometimes when I preview the animation it runs all the way through. Sometimes the animation preview stops at around 6 seconds. There is no explanation for why it cuts off and refuses to finish the animation. This happens randomly.
My e-mail address is [email protected] and my phone numbers are:
(515)327-2084 home
(903)269-7363 cell
SOURCE: having the same problem...
It is illagal to ask for a activation key. You have to get it from Adobe. That is the only legal way of going about this.
SOURCE: Adobe Photoshop Album Starter Edition 3.2 No unlock code
Hi! Try this! this must work..... Click here
Best of luck....
Peace!
SOURCE: No text or effects in
Yikes, it sounds like it may still be a driver issue. On the preview screen everything was fine before correct? I would try downloading different versions of the driver and see which version works with your software. I am not sure what OS you are running, I am going to use Vista as an example.. if you go to the VIA site and go to the drivers, they have previous versions of the drivers for all OS's....
Such as:
http://www.viaarena.com/ViaDisplayDrivers.aspx?Drivers.aspx?PageID=1&OSID=36&CatID=2900&SubCatID=185&Old=1&lang=en-GB
Use this page to select the pertinent information... then at the bottom of the driver page select "Click here for more versions of this support package."
http://www.via.com.tw/en/support/drivers.jsp
If none seem to work, they also recommend the Hyperion Pro drivers, you may just want to try starting with these:
http://majorgeeks.com/VIA_HyperionPro_4in1_Driver_d1618.html
