My water dispense model 87330 by hamilton beach will continue too run after cooling water..both fans are running..blue lite is on..dispenced water is cold..is this a thermostat problem please help
helloooo....im still waiting for a reply..can owner change thermostat out fairly easy ..or it worth the time..thanks for your time..doughelloooo....im still waiting for a reply..can owner change thermostat out fairly easy ..or it worth the time..thanks for your time..doug
You can't post conmments that contain an email address.
thanks alot for your info richard...is it posible to replace the thermostat,or test it by oneselfthanks alot for your info richard...is it posible to replace the thermostat,or test it by oneself
The two round "devices" on the tank are the operational thermostat, and the "safety" overtemp thermostat. It is usually the "operational" thermostat that fails, since it has to cycle a lot and arc internally. It is usually about 120-140 degrees F., and the safety thermostat significantly higher.
Unfortunatly this is going to be a bad heating element or high limit thermostat, It's going to be cheaper to buy a new one or just make do with cold water. Sorry I can't be more helpfull but i worked on these things for a while and the company i worked for would rather buy new then put time effort and parts into a $100 water dispencer.
if I can be of any more assitance please feel free to comment again.
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Glen, We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to. Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330). I believe the problem is in the circuit control board, but with out further testing i can't be sure .
hello.......is there a evident problem......
