Beverage-Air MT27 Beverage Cooler Commercial Logo
Anonymous Posted on Oct 10, 2017
I have a 7 yrs old beverage air mt27. The issue was "too cold" even I turned the temperature control knob down to almost off position. It froze all water and pops in it. Anybody have a similar problem or any idea. I thought of buying a temperaure control assembly (502-302B). I'll wait for some input then will give it a try. Thank you,
Jude24
Level 3:
Master:
  • Master 313 Answers
  • Posted on Oct 10, 2017
 Jude24
Master
Level 3:
Master:
Answers
313
Questions
Helped
95182
Points
1391
That temperature control assembly will most likely be the problem.
4 Related Answers
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Nov 17, 2009
SOURCE: Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
Anonymous
  • Posted on Jul 06, 2011
SOURCE: Looking for a wiring schematic
Hi there, I have a MT27 and also need wiring diagram. If you ever found one where can I get it please? Thanks Lee
Anonymous
  • 4 Answers
  • Posted on Nov 18, 2011
SOURCE: What does the overload relay look like a
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Gary
  • 210 Answers
  • Posted on May 12, 2013
SOURCE: Beverage-Air Kegerator Not Staying Cold
The internal temp will get down to 40 degrees but the fans won't shut off. We had to move it and when it defrosted, a lot of ice fell off the coils.
Can i use a beverage air mt27 as a freezer
Nope, You Can not. Compressors for freezers are different and if it set up as an fridge, you will not have enough defrost (on freezers there are heaters)
What will make a beverage air mt27 not cool
Multiple reasons. Is it turned on & set. Is the fan inside & out turning fast. Is there frost on a line at the compressor Is the compressor outside cabinet s/b hot & vibrating continually. Is the condenser (attached to compressor with radiator) warm/hot & not plugged with lint etc between the fins. ?????
2answers
Refrigerator runs and will not shut off, keeps getting colder and colder no matter what setting I put it on?
I have the same problem. My 7 yrs old Beverage Air model MT27 got very cold even with temperature control set to almost off position. It froze all the water and pops in it. Somebody have the solution?
Water is leaking from my Beverage-Air MT27 ?? Had moved it from one location to another. Delivery man laid it down and told me not to plug in for 24 hours. Was fine for 2 days now it is leaking water.
The condensate is supposed to drain from the evaporator down to a pan underneath by the compressor. Is is possible that the tube is not aligned with the pan any more. It is simple to check, remove the compressor compartment cover and inspect the pan and the tube. If the tube is out of place, just reposition it. This is likely the problem you are having. Also make sure the pan is correctly positioned.
What is the temperature for the thermostat settings?
i usually set mine at 38 or 40 that way things wont freeze but stay cold.
3helpful
Beverage Air
1. check for dirty condenser sometimes if its dirty enough, it'll trip the compressor.
2. if condenser is dirty, well pull out the old garden hose and hose down the condenser (turn off unit first!)(i don't want any accidents... je je je)
if you did step 2 and nothing yet, suspect faulty relay/ overload/ start capacitor failure (relay and start capacitors fail more often then the overload.
hope to he of some help today.
Top Beverage-Air Refrigerators Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
