SOURCE: Machine drains and dial turns directly to S after filling with water.
moe thasn likly you have a pressure switch that is either telling the machine its too full and making it drain or its not seeing the switch and so it drains. Another possibility ids the machine is leaking. Pull the lower cover off and make sure there is no water in the bottom. These askos have a float switch down there that will run the drain if the sense water leaking into the lower tray. Last but not least, you could have a bad timer. these timers are covered for 5 years (parts only) from date of installation. The first 4 digits of the serial # will tell yuo when the machine was made the firts 2 are the year and the second 2 are the week of that year (so a serial beginning in 0145 woul;d mean built in the 45th week of 2001 and so on. Good luck!
SOURCE: Shuts itself off before each Rinse or spin cycle.
Maybe your spin or rinse cycle button is in the off mode. Refer to your user's manual, if you hv one.
SOURCE: asko 10505 runs through was
hi sir'
start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
SOURCE: bowl won't turn or spin. belt is fine but motor
It sounds like you will need a new motor. You pump seems to work and that leads to the motor because it does not spin or move. Motor should be easy to replace good luck
