Sounds like the problem could be with your tig torch. Inside the tig torch you have a copper cable which carries your main welding current. If there is a break in the copper the high frequency is of such a high tension voltage that it can jump across the break in cable making it appear that your tig torch is fine. If you have a multimeter check continuity from one end of the torch to the other or try another tig torch.
