It happens with many brands. Coins are commonly found in the pump traps in most washers. I don't know if LG washers are more prone to eating socks, but if you try Google with 'lg washer sock', you will see that you are definitely not alone.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
