KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
Anonymous Posted on Oct 25, 2011
How to replace the grease, kind to use and where to get it
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
309
Points
You can buy the food-grade grease and get the free service manual from the following website. They also have a Kitchenaid mixer repair person to ask questions of.
http://www.mendingshed.com/kanew.html
1helpful
4answers
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
3helpful
Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
2answers
My K45SS is leaking some kind of oil or grease from the part of the mixer above where the mixer part attaches. It otherwise seems to be functioning fine.
its gear oil from the gear box that the motor turns to make the beaters turn,you need to replace the seals or keep adding food grade oil before you dry out the gearbox and ruin it
3helpful
My kitchaide mixer needs some oil as it is squeaky when it runs
Hi LIZYKAT15, you want grease not oil.
Your KA mixer came supplied with a ‘lifetime’ supply of grease for lubricating your mixers transmission gears. However, over time that grease breaks down and it should be replaced as part of a regular maintenance regimen for your mixer.
Ideally you want to replace the grease in your mixer with a ‘food grade’ grease (although I’ve see people use automotive bearing grease, too – your call.) Unfortunately you can’t just buy a ‘little’ grease, so the best option is to purchase a ‘cartridge’ and you’ll have enough to last you a lifetime of KA mixers. Try this link: http://www.grainger.com/Grainger/greases/ecatalog/N-9iv/Ntt-food+grade+grease?op=search&sst=All to get an idea of the grease available. You don’t necessarily need to purchase from Grainger, but when I fixed my wife’s mixer and needed to replace the grease in her mixer, the grease came from Grainger.
Here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer. Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Mine is a Chef Stand Mixer but really don't know model no. Where to find?
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause leaks.
To lubricate the unit, you need to spread again the grease in the gearbox, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
5helpful
Kitchenaid Mixer leaking oil
Hi Tim. Don't try to pour anything into the side openings, these openings are for the electrical brushes. You didn't state what model you have so my help is limited. Goto www.kitchenaid.com and click on the customer care tab. Enter your mixer's model# into the search window. Look for a parts catalog for your mixer. If there is one, download it.
Your mixer uses grease to lubricate it. If it's leaking oil, the oil and old grease must be removed and replaced. Chevron FM ALC EP-2 is a "Food Grade" grease, use it to replace the old stuff. The transmission housing and Planetary assembly will have to be removed to accomplish this. It's a messy, but necessary task. Once completed, run the mixer for a few minutes each week to keep the oil suspended in the grease, this will extend the life of the new lube. Good luck!
If this solution has assisted you please rate it. ricardok45.
5helpful
4answers
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Oil leaked from Kenmore mixer- model mumber 201
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
1helpful
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
3helpful
3answers
How do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
