Hi ! for a free wiring diagram, please visit the website below. If you need more information about a specific electrical issue you can reach me at [email protected].
http://www.motorpartstore.com. have a nice day.
SOURCE: link for down loading harley davidson road king repair manual
Not going to happen, copyright issues just like music. You may find it but.......
SOURCE: The check engine and battery light start to turn
might check alt.out put but check batt connections first get a book and follow the directions to ck AC output youll need to rev the motor some unless you have a three phase alt.which you might ,the book will tell you
SOURCE: oil change procedure 2000 road king
the oil tank is on the bottom of the transmission in your RK. There are two drain plugs. The plug towards the front left of the pan is the oil drain plug. The other one is for the transmission.
Drain the oil, replace the filter, refill with three quarts of oil and you're ready to go. The dipstick has two marks on it. The upper mark is "FULL HOT", and the lower mark is "FULL COLD". Do not overfill.
Don't forget to service the transmission and the primary at their recommended intervals.
Good Luck
steve
SOURCE: wiring diagram for tourpak on 2003 Harley Road King Ultra Classic
i have a 2003 ultra classic my riding lights keep blowing the fuse it wont do it sitting in the garage i have gone thru the wiring harnessing looking for the short fixed many things but still have the problem the turn signals work the brake lights still work so where do i look
