LG WM-2277HW Front Load Washer Logo
A
Anonymous Posted on Oct 23, 2011
My LG comes up with the error code PF - LG WM-2277HW Front Load Washer
Anonymous
Level 2:
Scholar:
  • Expert 60 Answers
  • Posted on Nov 02, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
60
Questions
0
Helped
33552
Points
108
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
  • hdiaz5620 Apr 25, 2012
    I used an extra extension cord to a different outlet, worked just like new.
I have an LG washing machine. It has a PF code. Simple things don't fix it
As LG states in troubleshooting section,
If your unit is displaying a "PF" error code, it means you've experienced a power failure. This may occur if the power supply to the washing machine is interrupted during a cycle from a power outage. To fix this, simply restart the washing cycle
LG Washer - Error Code List ' LG USA Support
NEW LG washing machine with PF error code
The "PF" error code on an LG washing machine typically indicates a power failure. This can be caused by a power outage, a tripped circuit breaker, or a problem with the electrical outlet or wiring.
LG WASHER/DRYER COMBO PF Issues
pf is power failure,, need to replace main board... there should be a parts/repair manual inside unit.. usually bottom panel...
Wm3431 pf code
The PF error code indicates a power failure. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle. If the error code continues to present after these steps have been taken, then the washer may require service.
1helpful
We are getting an error code of "PF" and can't
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
0-=0
PF code when on spin cycle
heatman101
3helpful
2answers
Getting a E1 code one the front panel and will not finish the cycle
There is not a reference for an E1 error code.
The listed LG error codes are:
IE, UE, OE, FE, PE, dE, tE, LE, EE, and PF.
May 18, 2010 • LG WM2016C
1helpful
PF CODE COMES UP WHAT IS LIKELY PROBLE
Found the below at http://lgknowledgebase.com
hope this helps,
best of luck, have fun,
thanks,
chuck
2answers
LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
