I have a waring blender and when I turn it on the pressure from inside pushes the lid off the top. The plastic cap actually blows off! What's up?
Are you blending something hot? When you blend a hot item the steam that is released will increase the pressure in the headspace above the contents in the blender. The lid will eventually blow off to release the pressure.
To avoid this problem begin blending with no more that one cup of ingredients. Before turning the blender on, remove the center lid insert to allow venting of steam. Blend on low speed. As you blend you can add another 1 1/2 cups of additional liquid through the opening in the lid.
Trust this method will resolve your problem.
Hello
There are two type of fittings for this gear. In some models it will be push in type, and for others it will be screw type. If your model has push type one, just pull out it from the shaft. You may have to excert a strong force to pull it out. If it is screw type, you have to open its lower lid by unscrewing its secrews, hold the cooling fan and hold the gear at the top, twist it in 'CLOCKWAYS' direction, [not counterclockwise], to screw it out. OK.
Answered by Gopakumar Gopalan 228 days ago
won't turn on
