To change the channel on the Hello Kitty KT2022 Walkie-Talkie:
-Tap the power button. The channel will blink.
-Use up/down arrows.
-Tap the power button again to save the channel selection.
The entire manual can be downloaded from here:
http://www.spectraintl.com/images/stories/pdf/hk/KT2022%20Manual.pdf
SOURCE: oregon scientific walkie talkies
Hi Neil
You can obtain the Owner's Manual (Contains simple instructions) from link below
http://www.expressfix.net/manuals/2WayRadios/OregonScientificTP329
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either + or – to turn On or Off.
3. Press the PTT to confirm or MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
SOURCE: I need a manual for a MJ270 walkie talkie,
This should direct you to the right place for a manual
http://www.motorola.com/Consumers/US-EN/Consumer-Product-and-Services/Two-way-Radios-and-Accessories/ci.MJ270R+Talkabout+Two-Way+Radio_US_EN.alt
SOURCE: walkie talkie symbol stuck on cannot remove it
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Best regards.
SOURCE: Is there a way I can change the channel on my
On the Motorolas you have to press the menu button until your current channel flashes. Then press the plus (+) or minus(-) sign to change the channel. 21 is a great channel and you can get distance on it.
