SOURCE: change bulb right rear blinker 2000 buick lesabre
you have to open the trunk take the carpet off right next to the very back of car undo the 3-4 plastic wing nuts take light off of car change bulb ......reinstall reverse of taking off
SOURCE: blinker wont work
try changing the bulb first
Testimonial: "There were two coils in the headlight and one was burned out...Thanks for the help."
SOURCE: i have a 99 buick century my drivers front blinker
change bulb in front if indicator doesnt blink or blinks fast if new bulb check socket connectors may have corrosion or damaged wiring
SOURCE: 1998 Buick Regal GS, Several problems are
start by checking the front wiring harness for corrosion , best is to do a continuity test on all the wires, look for corrosion in connecting harness, time consuming but the only way
SOURCE: my car stalls while driving and i can smell
for the signals check the flasher, put a new one in if you have the same problem then make sure grounds are good to those lamp sockets,the stalling i would start with the battery cable that goes to relay box under hood, common problem with those,the cable going to the box heat up melting the plastic around connection, making car stall and sometimes not starting depending on how bad it is. well start ther, good luck hope this helps.
