Http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
