Hello, welcome to FixYa.
The "E04" error code on your WFMC series Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining thus the error appears during the rinse/drain )
What you may have is either a partially clogged pump, debris blocking a hose or a faulty pump...the later being the least likely.
You haven`t mentioned if you`ve actually visually checked the pump...it is likely just that, a blocked pump.
Anyway, here`s the most likely way to remedy a E04 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
3. Find a drill bit or small screwdriver that fits in the hole in the round door.
4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. (you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan. This will deal with the door lock issue but it likely isn`t unlocking due to the water in the tub )
**There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.**
6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, or a lock, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly. Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
