Page 12 of the free manual details the process to remove the bypass filter (as shipped when new) and replacing a filter when the "Replace Filter" light comes on.
To reset the the "Replace Filter" light (page 11 of the manual):
Press and hold the Light and Lock pads until the Change Filter light blinks (approx 3 seconds) the control is now reset for 12 months or another 416 gallons of water.
Please rate my reply. Thanks & good luck!
thank you for your help! your advice worked;)
thank you Steve for your solution! It worked;)
You're welcome - I'm glad I could help!
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
If you have other questions please let me know, Thanks Sea Breeze
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
For some refrigerator models featuring water filters, the Water Filter Change Reminder function monitors the life of the filter and provides a reminder when it is time for the filter to be changed. When the system detects either 12 months of usage, or the filtering of 416 gallons of water (whichever comes first), the change filter indicator light will illuminate. This
indicates that the water filter should be changed and the light reset. To reset Change Filter Light:
Press and hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 seconds). The control is now reset for 12 months or another 416 gallons.
A more complete manual can be found here=> http://appliance911seabreeze.com/index.html
In left sidebar and last item listed. Go to page 101, Thanks, Sea Breeze
