SOURCE: Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
SOURCE: setting the time, day, date, ona Festina 16059/4
Alhamdulillah, the problem solved (at last) tks to IRONMAN
(http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2.
and then push it one click (dont push it to hard so it back to normal
position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
SOURCE: adjusting Date and day on a Festina 3 dial watch
2.
SOURCE: Festina chrono bike 16162
Pull the crown out to the first click, then you can turn one direction to set the alarm, and the other direction to set the date.
SOURCE: how do I set the time and date?
Twist the crown until you can pull it back one notch. This will set the alarm by twisting in one direction. If you twist it in the other direction, you will set the date. Pull back one more notch and this will set the time. One you've done this, push and tighten the crown back in and press the bottom right hand button. The second hand should begin moving.
