Hi Radhika,
Your TV has USB port on back side. Just plug your pendrive there. Then go menu on TV ( use your remote commander) and go to this input. Your TV will read the file on pendrive accordingly.
Regards
Hello
There is no direct USB port with this TV; and pen drive cannot be connected to it directly. You have to connect your pend drive direct to your laptop or desktop, and the RGB output of the computer should be connected to RGB input at the back of the TV, using an RGB connector wire; and you can see the pen dirve recordings via computer to TV. After connecting all perfectly, select the input mode of the TV to RGB in, then the Tv will act as a monitor to your computer.
No direct USB input is there with this model Sony set. You can oly connect it by this way only. OK.
