Hello & Welcome to FixYa NF error in your Maytag is
displayed due to no fill condition, when the washer tries to fill but is unable
to nf is displayed. Please check the water inlet valve for any clogs and
obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any
other questions. Kevin
What happen if i changed both valves and still get nf code
SOURCE: Maytag Neptune top loader washer not filling
You have tried both a Hot fill and a Cold fill and still no water flow?
You could try going into Service Mode and turn on the water inlet valves with console commands. See page 16 of the Service Manual and see if you can turn the water inlet valves one at a time and get water to flow into the machine. Getting into Service Mode is easy to do
The Service Manual for reference. Sears Parts Direct for reference.
If still no water flow it would be time to check 120VAC on the water valve solenoids when you command them on in Service Mode. If no 120VAC present then we might have a Stuck open High level pressure switch which would disconnect 120VAC to the Control Board relays that operate to switch 120VAC to the Hot/Cold solenoid valves.
How do you feel about troubleshooting? Do you have a DVM? I have the schematic in PDF format if you need. Let me know if you want to DIY the fix......Rich
