In most electronic devices there is a small fuss situated in side this could have blown. however if your device is still coverd have the shop repaire it for you
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair (refrigerator fan and main board). The board that was replaced actually had a burn mark on it where one of the components had fried. Standard computer plug strip surge protectors may not be large enough for a refrigerator load. I used a plug-in surge protector that is made for use in offices for copiers and large printers since it has the capacity to handle a refrigerator load. Make sure it is one that does not cut off power so the refrigerator will continue to operate if the protector is overloaded or fails.
Main system control memory IC fault. Check and replace it. If you wish to get more details visit the site linked here. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/
Hi Dfhamilton,
Damages due to lightening surge can go to any extent in a tv set. If you can, please open the back cover and check the fuse. Replace with the same rating one if you find it blown. Switch on the set. If it works, enjoy watching. If it blows again, please consult some TV tech.
Good Luck.
large power surges (many times greater voltage than normal) usually accompany a utility power outage , this can and most times will take out a devices power converter rendering it useless , have a qualified tech have a look at it , see what he thinks could be failure
always try and prevent sensitive (and expensive) electronic items from being damaged in power surges by using a surge suppressors , some of these include insurance to repair anything that's plugged into them , and always replace surge suppressors every 3-5 years , they do wear out !!
some utility's have insurance that u can purchase(extra) from them to pay for any repairs this might cause in future , ck with them 4 this
Hi Geoff,
You will need to open up your monitor. There will be a pcb fuse in the region of the mains input and you may need to replace some other components in that area which are designed to protect the monitor in just such an event as a power surge.
Unplug tv and let it set for a couple of hours. Remove the back panel, the fuse is located somewhere near where the power chord comes in. Remove fuse and replace with one of the same rating.
It's looking more and more like your monitor has given up normal operation --- to go inside the monitor is something that is very unwise for your typical user, and it is probably best to just replace the monitor --- sorry.
