Hi I have changed out the maytag and it takes a little time but it is easy to do ,
but costley, First of all turn off power or unplug unit, open the front of this unit and you will see to small screws top left and top right side, after removing the two screws then lift the top from the front, then all the wires will be visable to you, if you are not able to remember all the wires where there go then mark wires with masking tape or you can take a picture if you have a camara that you can use . like i said it is easy fix just take your time >
