If you can the QRS wave on its display for all the leads and if the machine is not prinding then the problem is with the printer side. First of all you have to check is the paper is inserted propely or not. If its ok then the motor or its driving section can becom faulty. Also there is one more chance is there the battery. If any of the cells in the battery is faulty then the machine will not get the proper voltage and fails to print. Its an 18V 1.4Ah battery. If you need the service manual for the machine then I'll sent the same. For that i need your email address. I can't upload that manual by fixya as it is in PDF format.
OK
OK
Hi, Also check one more thing enter to the Setup by pressing the Setup menu. Then select Operation mode. In the Operation mode select 12 lead then select No of copies. Then press 1 (if you press 0 then printer will be OFF if you press 1 you will get one copy) .exit setup pressing the setup button again. Then check the machine is it prints the ECG
