I've just done this 20 minutes ago.
Just between the 0-1-2 lever and the 0-1-2 script is a plastic catch (both sides)
Slide a medium screwdriver into the gap at this point, pushing hard and levering up.
This should just free the catch.
Do the same the other side and then lever the handle up. It will only go up about 1/2 inch.
Now go to the very front of the handle and do the same thing, both sides.
You should now be able to lever the top end of the front piece of handle past the middle piece that you levered up first, and then it will come off, revealing the front screw. Its made a bit more difficult because of the water jet, but comes off with a bit of a wriggle.
When you put this piece back on take care to get the water input spout into the tube before you push down too hard.
(My problem was a main power connector had burned out causing a short circuit and blowing the house circuit breaker. I soldered the connection and it seems to be working OK)
Richard
You can prise off the red plastic cover of the light at the front. Use a small screwdriver and insert it under the top. Then you'll see the screw. You'll need a hollow torx bit to undo the screw.
Follow Richard's instructions for the back of the iron.
