Garden Logo
amos hindsman Posted on Sep 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Xt140sb john deer pull string 2-cycle gas trimmer, low rpms, what should i do
Roy Cagle
Level 3:
President:
  • Master 1,545 Answers
  • Posted on Sep 30, 2011
Roy Cagle
Master
Level 3:
President:
Answers
1545
Questions
Helped
913741
Points
4781
An assortment of things could be causing low rpm's. If the machine is older, remove and check the muffler and exhaust port for carbon buildup. If the machine is only 2-4 years old, say, it probably needs a gasket and diaphragm kit (inexpensive) installed to restore the functionality of the carburetor. The ethanol present in todays gas, quickly ruins and dries out fuel lines and sensitive parts in the carb. Also, an important thing to check is the condition of the in-tank fuel filter and all fuel lines and primer bulbs. Post back after checking. Sorry for the late reply!
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Where is the fuel mixture screw on poulan pp133
On the carb. Low for initial and high for top end. Start with both at 2 1/2 turns out. Then adjust low when you pull the trigger to eliminate hesitation. Then floor it and hold while you adjust the high
1helpful
How do you replace the trimmer head on a john deere t105c 2 cycle trimmer ?
Have a JD T105C trimmer that starting "spitting gas out of it" when i try to start it!! It won't start and when it DID, it stalled right back out! Was used VERY LITTLE before this happened!
Nov 01, 2009 • Garden
2helpful
John Deere S1400 won't start
I have the same problem. I replaced the primer bulb, and the fuel lines. Still no gas to the bulb; (It ran fine before I replaced the primer bulb)
Sep 24, 2009 • Garden
1helpful
2 cycle gas mixtures
a safe mix is 25:1 but the correct mix for that machine is 32:1
John Deere String trimmer
your motor has an airleak..in the cranckcase..it could be warn out piston rings...must be an old unit
Mar 28, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
