FIRSTLY DEPENDING ON WHAT NOISE IT IS ITS GOING TO BE HARD FOR ME TO EXPLAIN TO YOU EXACTLY WHAT YOUR PROBLEM IS BUT I WILL GIVE YOU A FEW OPTIONS AS TO THE GENERAL NOISES.1 IF THE NOISE IS THERE ONLY WHEN THE MOTOR RUNS IT COULD BE THAT THE PISTONS INSIDE HAVE GONE FAULTY THAT MEANS THAE MOTOR NEEDS REPLACING.2 ALSO IF THE NOISE IS THERE WHEN THE FRIDGE IS RUNNING IT COULD ALSO BE A CABINET OR PIPE VIBRATION SOLUTION BEING LOCATE WHICH PIPE AND INSULT IT SO THE NOISE STOPS.3 IF ITS A GURGLING SOUND IT COULD BE A RESTRICTION ON THE CAPPILARY TUBE RESTRICTING THE GAS FLOW TO THE EVAPERATOR.THE FIRST TO CAN BE CHECKED BY YOU IF NOT BEST YOU GET A TECH TO ASSIST YOU.
GOODKUCK
MOHAMED
